No idea without the verbose. Of course, you can send via email.However, I've found an EFI online and using it doesn't trigger KP issue. Apparently, when booting using this EFI.. It stuck on the apple logo, do you know what issue is that? I can't attach the EFI file here bcs its to large, do you mind if I email u personally?
Still trigger KP.. may I ask where to see the verbose logs in format .txt?Disable IgnoreInvalidFlexRatio and then check!
Remove SSDT-PNLF and add -wegnoegpu to boot args. Reset NVRAM and then check. Also, it could be possible that the installer is dirty so re-create the bootable USB. For the verbose logging, you'll have to Debug version.Still trigger KP.. may I ask where to see the verbose logs in format .txt?
Add ForgedInvariant.kext and then check.This is the verbose abt the KP I guess, also I attach updated EFI
Well, the system is crashing so its not the bootable USB. Also, creating a installer on a USB Flash Drive or a high speed NVMe, it won't make that much of difference.Also I have a question, I'm not using any external drive to be a bootable drive. However, since I've 2 drive installed in this laptop, I've created 2gb Fat format partition on the 2nd drive and paste the required EFI and recovery folder to act as bootable drive. Will it be the cause of the problem? I just consider this method will make the installation run faster due to its connection via SATA, AHCI. I guess
Okay thanks for the adviceWell, the system is crashing so its not the bootable USB. Also, creating a installer on a USB Flash Drive or a high speed NVMe, it won't make that much of difference.
May I ask where is the kext file.... I've attached the file downloaded from GithubAdd ForgedInvariant.kext and then check.
