Catalina Installation with Intel HD Graphics 630
nobinkhan
Gigabyte Z390 Gaming SLI
Intel core i7 8700K
10.13.x
Hello Friends. I need your help to install Mac os Catalina in my system. Motherboard: Gigabyte Z390 Gaming SLI Processor: Intel Core i7 8700K 8th Gen Ram: 8GB Gpu: Intel HD graphics 630 I am tried to install before but every time after apple logo loading the monitor goes turned off. I have seen your Youtube tutorial but nothing help. I am running Macos Mojave right now in my system. Without usb 3.0/3.1 ,iMassage, Facetime everything is working. Here I attached my efi folder..
Please guys help me.....
Thanks for this friendly environment....
The EFI is too large. Read here:
ok, here is the latest file....
Here is PR files, IOReg, Kextcache output files....
Fix your profile. Your post says you're using Catalina and the profile says you're using macOS Mojave. 10.14.6
The file structure is not upto the mark.
The config.plist is not as per the guide.
The Clover is old.
Follow the guide here:
Sorry for the confusion, I am using Mojave and also trying to fresh install catalina. those files i attached before was from my mojave system which is working fine except usb3.0/3.1, imassage, facetime.......
Now, I made a catalina usb installer as your forum instruction and after using it following error occurred which i attached here as screenshot. (clover Bootloader 5100 Latest version).
Thanks again...
Thanks again...
Well, as per the FAQ, you should use the information for the system you're seeking help for. Not the system from which you're creating USB.
For making USB 3.0/3.1, you need a correct config.plist with the port limit patch.
For fixing your USB issue, create a separate thread in the Mojave Desktop support.
Submit the PR files for your Catalina and make sure to update your profile.
Actually I don't want to fix usb right now because with usb 2.0 i can continue installation. I want to make bootable usb for catalina. After installing catalina I will fix it.
Can you please help to make a perfect catalina usb installer.
I really need your help...
adamnor206
