How to install Win10 on hackintosh with clover
biglibigli
ASUSTeK X556UQK - laptop
Intel(R) Core(TM) i7-7500U CPU @ 2.70GHz, 2904 Mhz, 2 Core(s), 4 Logical Processor(s)
Intel(R) HD Graphics 620 - NVIDIA GeForce 940MX
10.15.x
Hi, how can I create WIN10 usb installer in my catalina hackintosh and install it on another disk(Not my mac disk).
I used these two method and got errors in both, am I in a right direction ?
1. have a USB EFI boot win 10, insert it and in clover load from it, then when I try to format.delete partition but every time it say can't install on this drive.
2. try to create boot USB with Boot camp assistant with download from action menu AND from Win 10 ISO but in both way got error.
thanks
thanks
What I suggest to do is to disconnect the power cable of other disks and only leave the disk that you wanna install windows on and once you are finished installing windows just attach back all the other disks and make the disk that has Clover on it the primary disk in BIOS and Clover will detect the Windows partition automatically.
Other wise you might not be able to install windows that easily.
That's the fastest way IMHO.
Good luck.
Reactions: biglibigli
Good luck.
good, do think I can do it by disable hard disk from BIOS ?
No I don't think that's gonna work.
P.S.
You can give it a try though, but if I remember correctly disabling it in BIOS didn't work for me.
alvarg82
