Start image failed
Iman
X510UQR
Intel(R) Core(TM) i5-8250U CPU @ 1.60GHz, 1800 Mhz, 4 Core(s), 8 Logical Processor(s)
Intel(R) UHD Graphics 620 and NVIDIA GeForce 940MX
  2. OpenCore (Legacy)
  1. MacBook
Startup image fails - aborted and comes with ‘no entry sign’ , please help
Attach the EFI you are using to boot!
The first .zip is the EFI folder I created by watching the video
Creating OpenCore EFI for Intel Desktops using Windows, Linux or macOS | Hackintosh | Step By Step​
and the 2nd .zip is the EFI folder I downloaded from Orilla Hackintosh. When I try the first .zip, Its show the startup image failed and a 'no entry sign' and when I'm using the 2nd .zip its shown failed due to panic mode. I really need help....:)
The attached zip file is corrupt. Please double check at your end.
So I need to resend my .zip file?
I hope this does not corrupt
This EFI I downloaded from Orilla
The motherboard,cpu(Kaby lake R) and gpu are the same but the bootloader is asus bios utility image.jpg
raymondleung416
