Available VM methods
Demian-mac
AMD Radeon
AMD Ryzen 7 47000U
Maibook M
I need to virtualize other systems from macOS somehow. Tell me the available virtualization methods other than virtualbox
There is Parallels, VMware Workstation, UTM. Then, there is Docker too. A lot of options are there.
МнеI need ways for my hackintosh
I have a Failed to power on VMware fusion VM startup error, parallels the same
Then there might be some issues at your end. What's your hardware specs?
CPU: AMD Ryzen 7 4700U
GPU AMD Radeon Graphics (with nootedred)
RAM: 24G
Disk:256G
Type: Laptop
RAM: 24G
Disk:256G
Type: Laptop
What's the problem with bare metal?
There are no problems with bare iron. Problem with vmware fusion. I was recommended to install VMware fusion 10, but there is an error Unable to retrive kernel symbols when starting the VM
Is there any specific reason you want to use VM instead of running it as bare metal?
jkzql77089
