SOLVED NootedRed doesn't work
Demian-mac
AMD Radeon
AMD Ryzen 7 47000U
Maibook M
I installed kext Nootedred. But after its installation, bootloop, but after its removal, everything is fine. Opencore and lilu of the latest versions
Attach the EFI you're using. Also, what version of NootedRed are you using? Does the BIOS has more than 512MB VRAM?
i'm using latest nootedred version
Please try from the link below:
Thank you, now everything worksThank you, now everything works!😄
  • Love
sapxdc96
