RX 460 no video after booting OOB
ru379
Chinese SZMZ B75 Chipset
Intel Xeon E3 1230 v2
Asus ROG Strix RX 460
Hi guys, I rencently bought an used asus rog strix rx 460 for my hackintosh build and all was working great in the installation but as soon as it finishes and the OOB screen is going to appear, there is just a no signal screen in my monitor. I tried disabling CSM with no result
Here are my specs
CPU: Intel Xeon E3 1230 v2
MB: Aliexpress Chinese SZMZ B75 Chipset MB (this is not the problem since with a GT 710 works great)
RAM: 16 GB DDR3 1600 MHz
SSD: SATA Samsung EVO 500 GB
GPU: Asus ROG Strix RX 460 4GB
macOS Version: Sonoma 14.6
EFI folder: https://easyupload.io/6bd35l
Here are my specs
Thanks for the help. I followed the guide and now my monitor detects a video signal but it is stucked at a black screen without cursor or any image
EDIT: Here is my new EFI
Is the BIOS UEFI or Legacy?
It is UEFI but I can also boot using legacy. Of course I'm using UEFI
What connection are you using for the display?
I'm using HDMI
Set ResizeAppleGpuBars to -1.
Also, there is no point in using dk.e1000=0 e1000=0 args as they're meant for Intel.
What macOS version are you trying to boot?
Ok I'll change that. I'm trying to boot macOS Sonoma 14.6
The problem persists without changes after doing that
adamnor206
