HELP: Installing MacOS Sonoma on Asus Vivobook M515UA R7 5700U
Here it goes.
Remove SSDT-CPUR. aml and check with SSDT-PLUG-ALT.aml.
Also, attach your BIOS Settings and try with DeVirtualiseMmio Quirk.
Also, some corrupt image will not boot. So, if you have a Mac, try a full offline installer.
You didn't change boot-args ncpi=0x100002 to npci=0x2000. attach modify config.plist
When you have make some change in OC, please Reset Nvram before you start .
Had no idea.
Thanks for that.
I'll redo all the tests and post back.
Hi! I did change it, but i'm creating different EFI folders for all the different tests/suggestions as i'm trying to create a comprehensive guide for my specific laptop.
Just redid the test and Reset the NVRAM first and got the exact same result.
Just tried with these settings and i keep getting the same result.
I don't have a Mac, so the method i used to generate the image was this: Create USB without Mac and Transmac
I'll add my bios settings as attachment.
adamnor206
