SOLVED Problems with booting Clover
The Ventura SSD is modifiziert (Root patched) with OCLP 0.60 for the HD4600 I use on the other Haswell without RX 560.
The Recover from Ventura doesn't work -gets stuck at :
But Sonoma 14.0 and the macOS 15 Beta 2 boot from Installer.
Seems the I must get a new Installer from Ventura.
Maybe Tommorow (can take maybe longer) I install Sonoma again on an Other SSD for Test.
Ah that's why. Yes, do a clean install and it should be all good :)
Thankyou for your Help!!!!!
It was the macOS with the Root Patch (OpenCore Legacy Patcher) what made the Problem with booting with the AMD RX 560.
Gretting from Germany, Franziska1993
PS: SonomaClean stands for Vanilla Install Only!
  • Love
Good hack!
As it was root patched, booting with SIP disabled and AMFI disabled, would have it booted. But a clean install is a clean install :)
As the original issue is resolved, closing this thread!
kod_mic
