 - Jul 19, 2024
 - SunrisePointLP
 - i3 7100U
 - Intel HD Graphics 620 Video Adapter
 - 14.x
 - iMac
Hello everyone, I would appreciate any help from you. I'll start from afar.
Before I started I checked if my Mini Pc is capable of running it.
It looks like:
My hardware is compatible with the following limitations:
WiFi: The network will work, but without Apple features (no AirDrop, AirPlay, Handoff, etc.)
Bluetooth: Bluetooth will work except for Logitech devices. Devices using the Logitech Unifying receiver will work. (And I have it as well, but I also have wire Keyboard.
As an Attachment I added the HTML report from AIDA.
So far so good. I started with the guide from dortania, from the very beginning to the very end. Unfortunatelly without any luck.
I prepared the USB with Rufus, then I downloaded the Mac OS Sonoma with macrecovery under CMD and as result i got BaseSystem.dmg (around 750mb file), I understood that under Windows I can just do online instalation, and under Mac the offline one.
So after that i startet working with Open Core, finding Kexts, drivers , etc. and for Kaby Lake the ACPI aml files..
After that I did use ProperTree to obtain all the infromation and to change True and False here and there using the Dortania Guide.
The GenSMBIOS-master was also part of the joy for the Serial Number etc. As I was done with doing all of this I saved the config.plist
Maybe I forgot few Steps, which I cant remeber right now, but this is it in a nutshell.
So here we got few screenshots of the structure of the folders, as well I added my Efi Folder with the hope you guys check over it and maybe add or delete the things I dont need.
I appreciate any help you can provide.
It looks like:
