[Solved] Help for error on running sketch trial
biglibigli
ASUSTeK X556UQK - laptop
Intel(R) Core(TM) i7-7500U CPU @ 2.70GHz, 2904 Mhz, 2 Core(s), 4 Logical Processor(s)
Intel(R) HD Graphics 620 - NVIDIA GeForce 940MX
10.15.x
Hi, I just finished installing Catalina on Asus x556u. I used rehabman realtek v2-2017-0322 for add ethernet.
I get sketch 61.1 trial version from it's site. But first time I run it says can't verify license. But I just installed Mac os and it's trial version. (Attached photo)
First I think it must be caused by network, because I didn't use any kext for fixing my network but after I fix ethernet driver it still say same error. I think this is not caused by the app and I must do something else in os :confused:
Do you have any idea what's causing this ?
The OS has nothing to do. Did you entered the registration or License key and tried to activate? An internet connect is required i guess.
Reactions: biglibigli
you was right. it was needed to connect internet once after that its running. thanks
GabyXB
