[Solved] Help for error on running sketch trial
biglibigli
ASUSTeK X556UQK - laptop
Intel(R) Core(TM) i7-7500U CPU @ 2.70GHz, 2904 Mhz, 2 Core(s), 4 Logical Processor(s)
Intel(R) HD Graphics 620 - NVIDIA GeForce 940MX
10.14.x
Clover (UEFI)
Android
Hi, I just finished installing Catalina on Asus x556u. I used rehabman realtek v2-2017-0322 for add ethernet.
I get sketch 61.1 trial version from it's site. But first time I run it says can't verify license. But I just installed Mac os and it's trial version. (Attached photo)
First I think it must be caused by network, because I didn't use any kext for fixing my network but after I fix ethernet driver it still say same error. I think this is not caused by the app and I must do something else in os :confused:
Do you have any idea what's causing this ?
GIGABYTE Z370 AROUS GAMING 3
Intel Core i9 9900K
11.0.x
OpenCore
MacBook Pro
Android, iOS
The OS has nothing to do. Did you entered the registration or License key and tried to activate? An internet connect is required i guess.
Reactions: biglibigli
biglibigli
10.14.x
Clover (UEFI)
Android
you was right. it was needed to connect internet once after that its running. thanks
Intel Core i9 9900K
11.0.x
OpenCore
MacBook Pro
Android, iOS
