897987
Hi EliteMacx86
I have a Dell Inspiron Ultrabook 14' Laptop I succesfully install BigSur everything works.
Now I'm getting struggle with Sonoma 14.4, I managed to install it without problems but - No audio, No Wifi, Graphics installed but not smoothly, Camera work, Ethernet work, Bluetooh work, etc... if somebody can help me to make this posible and make everything works I really appreciate it.
Here is my laptop specs:
CPU: Ivy Bridge Intel i5 3317U
RAM 16GB DDR3
GPU: Intel HD Graphics 4000
Audio Codec: IDT 92HD91BXX
Ethernet Card: Qualcomm Atheros AR8162
Wifi/BT Card: Intel Centrino Wireless-N 2230
If you need additional information, tell me.
Well, that's because Sonoma does not include support for Ivy Bridge Graphics. Therefore, you can run OCLP to patch the system and you should be good to go!
Regarding WiFi/BT, you can use the Intel WiFi guide on the forum!
For Audio, you need to inject a proper layout ID. If it does not work, you'll need to fix IRQ Conflicts as indicated in the original guide.
Reactions: CarlDx
Thanks for your reply.
Can I send my config.plist to you to get a more specific orientation of what to do and what not or anything i have to fix or remove in there.
Please and sorry for the bother.
Yeah, attach the complete EFI to have a look!
Here it is, I hope you can help me solve it and get everything working. Thanks in advance...
The EFI needs some cleanup!
sammrafi
