SOLVED I can't restore the functionality of the Brcm Internet module
AnnaMarua
ASUS VivoBook 15 X512JA-BQ1021
Intel Core i3 1005G1
Intel UHD Graphics
Hello fellow hackers. The problem is with my BCM94360CS2 broadcom, I followed this guide:
However, nothing helps, the SIP is disabled, the security module is also disabled, the system was patched with the latest OCLP 1.5.0, after the patch only Bluetooth is launched, the Internet also continues to remain dead
Of all the Kexts, I have only the AirPortBrcmNic injector disabled, since it calls Daemon 'PXSX' (I'll attach a screenshot below) and even with the presence of an injector, nothing works
Please help me, I'm sure it can be started, but I don't understand how, I've been puzzling over this for the third day, and yes, the moudle is definitely working, since I upgraded to sonoma from ventura
I have attached files below that may help
Opencore version 1.0.0
OCLP 1.5.0
Kexts are all the latest version
all screenshots were taken on mac OS version 14.5 after the system patch
The BCM94360CS2 Wi-Fi module itself is removed from the original MacBook and connected to my laptop via an NGFF M.2 adapter
I will provide additional files if necessary
UPDATE:
in general, the update, I was able to launch my Internet, As the administrator said earlier, I need to download from the Skywalk acidantera github
as well as the problem turned out to be one error made in blocking the kernel
it was written in my config:
com.apple.iokit.IOSkyWalkFamily
But it should be:
com.apple.iokit.IOSkywalkFamily
As a result, opencore did not block the kexts located in the SLE, as a result, it caused a kernel error due to the fact that two cupcakes conflicted with each other, after correcting the letters in the kernel lock, the system successfully booted and identified my Internet module
  • Config and Ioreg.zip
OCLP 1.5.0
Does the system get stuck during boot or it boots fine and the WiFi doesn't work?
If you add an AirPortBrcmNic injector, then the system takes a very long time to load by sending me Daemon 'PXSX', eventually it starts, but there is no Internet, and legacy pater does not offer to patch the system, if you do everything without an injector, legacy patcher sees the module and prompts me to patch it, after which Bluetooth starts and only, i.e. the Internet is just No
So, eventually, you can boot, just no internet. Is that correct?
mac300
