How to build 6950 xt SSDTs in windows - prep for Sonoma
bhuether
Asus Z790 ProArt Creator
i7 14700k
6950 XT Red Devil
Hi, been reading here and elsewhere about getting 6950xt working on Sonoma. I am using it with i7 14700K, Asus Z790 ProArt Creator. I built SSDT-GPU-SPOOF with dortania instructions. Also I built SSDT-BRG0 with SSDTTime, sincein windows I see unnamed PCI bridges.
The spoof DSDT looks like
// Based off of WhateverGreen's sample.dsl
// https://github.com/acidanthera/WhateverGreen/blob/master/Manual/Sample.dsl
DefinitionBlock ("", "SSDT", 2, "DRTNIA", "AMDGPU", 0x00001000)
External (_SB_.PC00, DeviceObj)
External (_SB_.PC00.PEG1.PEGP, DeviceObj)
Scope (\_SB_.PC00.PEG1.PEGP)
if (_OSI ("Darwin"))
Method (_DSM, 4, NotSerialized) // _DSM: Device-Specific Method
Local0 = Package (0x04)
// Where we shove our FakeID
"device-id",
Buffer (0x04)
0xBF, 0x73, 0x00, 0x00
// Changing the name of the GPU reported, mainly cosmetic
"model",
Buffer ()
"AMD Radeon 6950 XT Red Devil"
DTGP (Arg0, Arg1, Arg2, Arg3, RefOf (Local0))
Return (Local0)
Scope (\_SB.PC00)
Method (DTGP, 5, NotSerialized)
If (LEqual (Arg0, ToUUID ("a0b5b7c6-1318-441c-b0c9-fe695eaf949b")))
If (LEqual (Arg1, One))
If (LEqual (Arg2, Zero))
Store (Buffer (One)
0x03
}, Arg4)
Return (One)
If (LEqual (Arg2, One))
Return (One)
Store (Buffer (One)
0x00
}, Arg4)
Return (Zero)
The bridge:
// Source and info from:
// https://github.com/acidanthera/OpenCorePkg/blob/master/Docs/AcpiSamples/Source/SSDT-BRG0.dsl
DefinitionBlock ("", "SSDT", 2, "CORP", "PCIBRG", 0x00000000)
* Start copying here if you're adding this info to an existing SSDT-Bridge!
External (\_SB.PC00.PEG1.PEGP, DeviceObj)
Scope (\_SB.PC00.PEG1.PEGP)
Device (BRG0)
Name (_ADR, Zero)
// Customize this device name if needed, eg. GFX0
Device (PXSX)
// Target Device Path:
// PciRoot(0x0)/Pci(0x1,0x0)/Pci(0x0,0x0)/Pci(0x0,0x0)/Pci(0x0,0x0)
Name (_ADR, Zero)
* End copying here if you're adding this info to an existing SSDT-Bridge!
The thing is, it is not clear if I need to rename PXSX to GFX0 or something, and as I understand looking through DSDT is needed to determine if rename is needed. I attached DSDT dump if useful.
Ideas?
thanks!
Forgot to add, windows shows for my GPU
PCIROOT(0)#PCI(0100)#PCI(0000)#PCI(0000)#PCI(0000) PciRoot(0x0)/Pci(0x1,0x0)/Pci(0x0,0x0)/Pci(0x0,0x0)/Pci(0x0,0x0)
ACPI(_SB_)#ACPI(PC00)#ACPI(PEG1)#ACPI(PEGP)#PCI(0000)#PCI(0000)
\_SB.PC00.PEG1.PEGP
Here's how to spoof:
Is this tutorial works for rx6950xt on OSX 10.14 Mojave? Do I need to use some additional kext to get GPU to work on Mojave or I can do a DSDT GPU SPOOF alone?
Please do not create multiple posts for the same issue.
See the original reply here:
wyattst99
