HP Pavilion 23-q127c TouchSmart All-in-One Desktop PC - Intel Core i5-4460T - 8GB RAM - Intel HD Graphics 4600
This is a complete installation guide to install macOS Big Sur 11.1 on HP Pavilion 23-q127c. The purpose of this guide is to provide a step-by-step guide to install Big Sur using OpenCore UEFI.
Specifications
ComponentModel Number
Desktop AIOHP Pavilion 23-q127c
ProcessorIntel Core i5-4600T
RAM8GB 1600MHz
GraphicsIntel HD Graphics 4600
SSDPNY CS900 240GB
Audio2W Built-In Speakers, Realtek ALC280
Display
EthernetRealtek RTL8168GU/8111GU PCI Express Gigabit Ethernet
Wireless/BluetoothReplaced with Broadcom BCM94352Z, NGFF, M.2, A+E Key Type
WebCamHP High Definition 1MP Webcam (Sonix Technology Co., Ltd.)
TouchscreenMultitouch V3106 (ILITEK)
Ports1 x DC Power Input | 1 x Ethernet | 4 x USB 2.0 (Type A) | 1 x HDMI | 2 x USB 3.0 | 1 x 3.5mm audio combo jack | 1 x SD Card slot
Summary
FeaturesStatus
GraphicsYES
Built-in AudioYES
BrightnessYES
TouchscreenYES
HDMIYES
HDMI AudioYES
WebCamYES
EthernetYES
WiFi/BTYES
AirDropYES
HandoffYES
Power ManagementYES
App StoreYES
iMessageYES
FaceTimeYES
iCloudYES
USB 2.0, and USB 3.0 PortsYES
Not working
  • Everything works like a charm.
Bootable Media Creation
2. Plug USB to your system.
4. Close Disk Utility.
5. Open Terminal and type:
6. Enter your password
  • At this point, the bootable USB can be only used to boot Mac only. In order to boot the computer using the USB, follow the steps below.
Preparing OpenCore Bootloader
DirectoriesDescription
DocsContains documentation, change log, a sample config.plist, and ACPI Samples for OpenCore.
IA32Contains OpenCore EFI, 32-bit OpenCore Boot Loader.
UtilitiesContains several utilities.
X64Contains OpenCore EFI, 64-bit OpenCore Boot Loader.
Adding Required SSDTs
SSDT NameNotes
SSDT-EC
  • This SSDT fixes EC and USB Power.
  • This SSDT is required for proper USB Power.
SSDT-PLUG
  • This SSDT enables Power Management function.
  • This SSDT is required for a proper CPU and GPU Power Management.
SSDT-PNLF
  • This SSD enables PNLF attaching to display.
  • This SSDT is required for Brightness function.
Adding Required Drivers
Driver NameRequiredNotes
OpenRuntime.efiYES
  • Runtime driver including several other drivers merged such as ApfsDriverLoader.
  • OpenRuntime.efi is a replacement for AptioMemoryFix.efi driver.
OpenHfsPlus.efiYES
  • Provides reading of HFS+ Volumes/drives in OpenCore Boot Picker.
OpenCanopy.efiOptional
  • Provides GUI functionality for OpenCore Boot screen.
  • This driver is required if you need GUI or theme for OpenCore.
AudioDxe.efiOptional
  • Provides Boot Chime support.
  • Only required if you want to use Boot Chime
3. From the EFI/OC directory, just keep the above drivers and delete rest of the drivers.
  • All the drivers can be found at: X64/EFI/OC/Drivers
Adding Required Kexts
Kext NameRequiredNotes
LiluYES
  • Provides arbitrary patching.
VirtualSMCYES
  • Emulates Apple hardware. VirtualSMC is a successor of FakeSMC.
  • This kext requires "Lilu.kext" to function.
WhateverGreenYES
  • Provides GPU patching on macOS.
AppleALCYES
  • Provides Audio support on macOS.
AppleBacklightFixup.kextYES
  • Enables Backlight Slider in System Preferences>Displays
USBInjectAllYES
  • Enables USB ports for mapping USB ports further.
  • It's advised to map the USB ports during the post-install for a better USB speed, improved sleep/wake and hotplug.
RealtekRTL8111YES
  • Enables Realtek RTL 8111/8168 Family onboard Ethernet Controller.
1. Download the above kexts.
Notes
  • Do not download the project files. The pre-built binaries/downloads are available in the README.md section. Make sure you read it carefully.
  • Use the kext from RELEASE folder and RELEASE.zip file.
  • Do not place unnecessary kexts here. It might prevent booting the installer.
  • Only use basic kexts which is required to boot off the installer. You can install the rest required kexts at the time of post-installation.
  • The VirtualSMC package includes Battery and Sensors plugins (SMCBatteryManager.kext, SMCDellSensors.kext, SMCLightSensor.kext, SMCProcessor.kext, and SMCSuperIO.kext). You do not need these kexts for booting the installer.
ACPI>Add
SSDT NameNotes
SSDT-EC
SSDT-PLUG
SSDT-PNLF
ACPI>Patch
Table Signature*FindReplaceCommentEnabledNotes
DSDT4548433145483031Rename EHC1 to EH01 (USB)*YES
  • Renames EHC1 to EH01 for proper USB functioning.
  • This rename is required for fixing USB Ports with EHCI Controller.
  • Rename #1
DSDT4548433245483032Rename EHC2 to EH02 (USB)*YES
  • Renames EHC2 to EH02 for proper USB functioning.
  • Rename #2
DSDT4844415348444546Rename HDAS to HDEF (Audio)YES
  • Renames HDAS to HDEF for Audio.
  • This rename is required for implementing Audio Function.
Notes:
  • The EHC renames must be used in the conjunction to enable the proper USB renaming.
  • *Requires both renames for full function.
Booter>Quirks
QuirksValueNotes
AvoidRunTimeDefragYES
  • Fixes certain UEFI runtime services such as date time, NVRAM, power control, etc.
EnableSafeModeSlideYES
  • Patch bootloader to have KASLR enabled in safe mode.
  • This quirk requires ProvideCustomSlide to be enabled.
EnableWriteUnprotectorYES
  • Allows write access to UEFI runtime services code.
ProvideCustomSlideYES
  • Provide custom KASLR slide on low memory.
  • This option forces macOS to use a pseudo random value among the available ones.
SetupVirtualMapYES
  • Setup virtual memory at SetVirtualAddresses.
  • Fixes several virtual address issues and tends to fix early Kernel Panics.
SyncRuntimePermissionsYES
  • Update memory permissions for runtime environment.
ProvideMaxSlide0
  • Provide maximum KASLR slide when higher ones are unavailable.
Note:
  • The values which have been not discussed above, that will remain disabled.
DeviceProperties
This section is used for adding device properties. This includes PCI Devices information such as Graphics, Audio, WiFi, Ethernet and other controllers. This section will remain completely untouched as everything is handled by WEG automatic patching.
Kernel>Add
ArchBundlePath*ExecutablePathPlistPathEnabledNotes
AnyLilu.kext**Contents/MacOS/LiluContents/Info.plistYES
AnyVirtualSMC.kext**Contents/MacOS/VirtualSMCContents/Info.plistYES
  • VirtualSMC is a successor of FakeSMC.
AnyWhateverGreen.kext**Contents/MacOS/WhateverGreenContents/Info.plistYES
AnyAppleALC.kext**Contents/MacOS/AppleALCContents/Info.plistYES
  • Enables onboard/built-in Audio.
AnyAppleBacklightFixup.kext**Contents/MacOS/AppleBacklightFixupContents/Info.plistYES
AnyUSBInjectAll.kext**Contents/MacOS/USBInjectAllContents/Info.plistYES
  • Enables USB ports.
  • It's advised to map the USB ports during the post-install for a better USB speed, improved and sleep/wake.
AnyRealtekRTL8111.kext**Contents/MacOS/RealtekRTL8111Contents/Info.plistYES
Notes:
  • All the plugins must load after loading it's dependencies otherwise the kext will no longer function even when loaded in OS X/macOS.
  • The mandatory kexts must be loaded in sorted order as shown in the above table.
  • *Indicates BundlePath i.e. Name of the Kext
  • **Indicates mandatory kexts.
  • All the added kexts must exists in the EFI/OC/Kexts directory.
  • The options which have been not discussed above, that will remain untouched.
Kernel>Scheme
OptionsValueNotes
FuzzyMatchYES
  • Enables checksum ignore with kernel cache instead of using latest cache available.
  • This setting allows matching the latest kernel cache with a suitable architecture when the kernel cache without suffix is unavailable, improving macOS 10.6 boot performance on several platforms.
KernelArchAuto
  • Determines Kernel Architecture.
KernelCacheAuto
  • Determines Kernel Cache.
Kernel>Quirks
QuirksValueNotes
AppleCpuPmCfgLockYES
  • Disables PKG_CST_CONFIG_CONTROL (0xE2) MSR modification in AppleIntelCPUPowerManage- ment.kext, commonly causing early kernel panic, when it is locked from writing.
  • Enable this quirk if you cannot disable CFG-Lock in BIOS/UEFI.
AppleXcpmCfgLockYES
  • Disables PKG_CST_CONFIG_CONTROL (0xE2) MSR modification in XNU kernel, commonly causing early kernel panic, when it is locked from writing (XCPM power management).
DisableIoMapperYES
  • Disables IOMapper support in XNU (VT-d), which may conflict with the firmware implementation.
  • This option is a preferred alternative to deleting DMAR ACPI table and disabling VT-d in firmware preferences, which does not break VT-d support in other systems in case they need it.
  • Enable this quirk if you cannot disable VT-d in BIOS/UEFI.
LapicKernelPanicYES
  • Disables kernel panic on AP core lapic interrupt.
  • Equivalent to Clover's Kernel LAPIC.
PanicKNoextDumpYES
  • Prevent kernel from printing kext dump in the panic log preventing from observing panic details.
PowerTimeoutKernelPanicYES
  • Disables kernel panic on setPowerState timeout.
  • Fixes kernel panics related to power changes with Apple drivers in macOS Catalina, most notably with digital audio.
XhciPortLimitYES
  • Enables 15 port limit patch.
  • This quirk is a temporary solution and is advised to map your USB ports during post-installation.
DisableLinkeditJettisonYES
  • Disables __LINKEDIT jettison code.
  • Provides more reliable performance without keepsyms=1
  • This quirk is required for macOS Big Sur.
Note:
Kernel>Patch
Identifier*CommentFindReplaceEnabled
com.apple.iokit.IOAHCIBlockStorageEnable TRIM for SSD00415050 4C452053 53440000000000 00000000 000000YES
NVRAM>Add
UUIDKeyValueTypeNotes
7C436110-AB2A-4BBB-A880-FE41995C9F82boot-args
  • -v
  • debug=0x100
  • keepsyms=1
  • alcid=4
STRING
  • Adds boot args which provides several functions.
-v
  • Enables verbose mode. Helpful to track the installation progress or when booting.
debug=0x100
  • This disables macOS's watchdog which helps prevents a reboot on a kernel panic.
keepsyms=1
  • This is a companion setting to debug=0x100 that tells the OS to also print the symbols on a kernel panic.
  • This can give some more helpful insight as to what's causing the panic itself.
alcid=4
  • Sets Layout ID = 4 for Onboard/Built-In Audio.
csr-active-config
  • 00000000
DATA
  • Defines SIP type.
00000000
  • Enables SIP completely. (0x0)
  • It's advised to configure SIP via recovery using "csrutil."
  • For more information on SIP, check the SIP disabling guide.
prev-lang:kbden-US:0STRING
  • Sets Keyboard language.
PlatformInfo
Suggested SMBIOS
SMBIOSCPU
iMac 15,1Intel Haswell for i3 i5 and i7
DataHub
OptionValueNotes
Add this section in config.plistYESAdds DataHub field
Generic
OptionsValueNotes
Add this section in config.plistYESAdds Generic field
from SMBIOSYES
ProcessorType0
  • Sets SMBIOS Processor Type.
  • This will override your actual CPU type.
  • It's recommended to set this option to "0" to detect the original CPU by macOS instead of using SMBIOS CPU Type.
SystemMemoryStatusAuto
  • Indicates whether system memory is upgradable in PlatformFeature. This controls the visibility of the Memory tab in About This Mac.
Auto
  • Use the original PlatformFeature value.
  • It's recommended to set this option to "Auto."
Upgradable
  • Explicitly unset PT_FEATURE_HAS_SOLDERED_SYSTEM_MEMORY (0x2) in PlatformFeature.
Soldered
  • explicitly set PT_FEATURE_HAS_SOLDERED_SYSTEM_MEMORY (0x2) in PlatformFeature.
SpoofVendorYESSets SMBIOS vendor fields to Acidanthera
PlatformNVRAM
OptionValueNote
Add this section in config.plistYESAdds PlatformNVRAM field
SMBIOS
OptionValueNote
Add this section in config.plistYESAdd SMBIOS field.
UEFI
This section is for adding UEFI drivers and related settings. The following changes are needed.
Quirks
OptionsValueNotes
IgnoreInvalidFlexRatioYES
  • Some types of firmware (such as APTIO IV) may contain invalid values in the MSR_FLEX_RATIO (0x194) MSR register. These values may cause macOS boot failures on Intel platforms.
  • This quirk is required for all pre Skylake motherboards.
UnblockFsConnectNO
  • Some types of firmware block partition handles by opening them in By Driver mode, resulting in being unable to install File System protocols.
  • This quirk is required for HP Motherboards.
Note:
The values which have been not discussed above, that will remain as default values.
Installing OpenCore EFI
2. Copy the EFI from your working directory to EFI partition of your Bootable USB Flash Drive.
Now you’ve successfully installed OpenCore, the required drivers, kexts and config.plist and the USB Flash drive is ready to boot off your computer.
UEFI Settings
SettingsValue
SATA EmulationAHCI
Network BootDisabled
Virtualization TechnologyEnabled
Legacy SupportEnabled
Secure BootDisabled
Fast BootDisabled
Once the UEFI is setup, Save & Exit Setup
Installation
Turn on your system.
6. Repeat step no. 5.
NameMacintosh HD
FormatAPFS
SchemeGUID Partition Map
12. Close Disk Utility.
This will take couple of minutes and will restart at "Less than a minute is remaining". Upon completion, the system will automatically restart. The System will restart to complete the installation. Here it ends the first phase of the installation.
Post Installation
Now, configuring the Post Installation. There is not much to do for the postinstallation except configuring WiFi/BT and the boot from system drive. Everything rest is fully functional.
WiFi/Bluetooth
The stock card has been replaced with Broadcom BCM94352Z. To activate the WiFi and Bluetooth, you'll need to install some kexts and add some patches. For more information, read here:
Boot from System Drive
3. Open your EFI Partition of your Hard Drive.
6. Copy the EFI folder from your macOS Bootable USB to your EFI Partition of your Hard Drive.
By using this method, you’ll be easily able to install OpenCore Boot loader on your System Drive.
Restart your AIO
After completing the post installation, restart your AIO.
App Store, iMessage, FaceTime, and iCloud
1. Mount your EFI partition
2. Open your config.plist
3. Navigate to Platform Info Tab
4. Generate a new SMBIOS for "iMac15,1"
5. Save your config.plist
6. Restart your AIO
7. Login into App Store, iMessage, FaceTime and iCloud.
Conclusion
You should have all the functions as stated above.
Credits:
Hello. I have i5-4460T | Lenovo b40-30 H81 | HD4600 | Opencore 0.9.8
So all working good, but i have one trouble. After wake up display backlight level is low and does't change. After reboot backlight works good.
Please help if you can.
Is NVRAM working?
Secondly, check ALS.
Is NVRAM working?
Hello.
I checked nvram is working - yes, i get variable after reboot.
I add SSDT-ALS0 and smclightsensor.kext - the same situation.
I check backlight level in hackintool nvram section before and after wake up - <d90a> it's max brightness.
I add ioreg after wake up.
sapxdc96
