AMD Ryzen 5 5700G - succesfull install but system not loading
yarecco
Hi all.
I successfully managed to install Mac OS on MSI PRO DP20Z 5M with Ryzen 7 5700G with integrated graphics.
System installs properly ( both Ventura and Sonoma tried). I can boot to mac os recovery without any issues. But after installation when system should boot normally it stucks.
I did all required settings in BIOS ( disabled fastboot, secure boot, CSM and set VRAM to 2G). I put NootedRed into kexts and enabled it in config.plist.
What else am I doing wrong?
Any help and suggestions please?
Thank you
  • config.zip
    config.zip
Hi all.
Thank you
Use iMac20,1 SMBIOS and then check.
OK
finally I managed to install and boot Ventura on my Ryzen.
My appetite grows so I wanted to update to Sonoma but failed again.
What changes should I make in my OC comparing to Verntura to properly boot to Sonoma?
OK
Are you talking about the reboot loop during the update?
Make sure your kexts are upto date and the OC. In addition, disable SecureBootModel and you should be good to go!
However, you must run the update again.
Kext were up to date. It simply needed more time to install. Even if it looks like stuck it still working and after 15 minutes installation went thru.
I was able to update to 14.5 beta4 without any issues.
Sounds good!
OK
Efi Please
J.An
