[Guide] Gigabyte GA-H110M-S2 - Intel Core i5 7400 - NVIDIA GeForce GT 710
wher i found it
Firstly fix your profile.
Follow the guide here:
Can I use i3 7100 ?
Please reply..
Thank you...
Dear friend I decided to buy core i5 6500 model from my friend. Is this fully compatible for gigabyte H110M-S2 or not ?
Please reply...
Thank you...
Please reply...
Thank you...
It's fully supported.
Reactions: Prathapsingh
where i download macOS Mojave 10.14 (18A391) mac app store version ?
Because the Appstore shows 10.14.6 version Only.
i bought core i5 6500, GA H110M S2, Vengence LPX 8bg 2400 MHz Ram, 250 gb ssd..
im new to mac.
so please be very clear the procedure..
thankyou...
Why you need old version?
Yes. Go for 10.14.6 only.
Thank You..Already i have 10.14.6 original dmg file.
can i use this ? or download app store version ?
DMG? App Store never gives a DMG file. Probably you have downloaded it from somewhere else. If it's vanilla, you can use it. If not, download it from App Store.
J.An
