NootedRed black screen ASUS A320M-K + AMD Athlon 3000G int Radeon Vega 3
omg1
ASUS A320M-K
AMD Athlon 3000G
int. AMD Radeon Vega 3
Mobo - ASUS PRIME A320M-K
CPU — AMD Athlon 3000G with Radeon Vega 3
Display connected over D-SUB (VGA).
May be important? -> NVME storage inserted to PCI-E slot over adapter (my cpu don't have pci-e lines on original m2 connector)
Bootloader - OpenCore 0.9.7
Using NootedRed.kext v1.0.0-RELEASE
BIOS:
  • Above 4Gb - Enabled
  • CSM - Disabled
  • IOMMU - Disabled
  • Serial Port - Disbled
  • VT-D - Enabled
  • Multimonitor - Disabled
  • Primary Video - IGFX
  • OC boot-args: npci=0x2000 unfairgva=1 alcid=11 -v debug=0x100 keepsyms=1
After boot strings display blank (black screen). But over ~10..20 reboot/shutdowns it may "fly up" and work. I try more things… change in BIOS Multi monitor option. Try connect TV over HDMI...playing with boot-args… Very randomly OS booting normal and work, but more frequently just black screen. Try `-NRedDPDelay` but not have stable result...
But...then black screen PC with MacOS can be ping and i can login over SSH. Access over VNC (shared display) don't work.
How solve this trouble?
Proof sometime (randomly...) it work:
Opps) Admin/Moder - move this thread to https://elitemacx86.com/forums/graphics-and-displays.264/
BIOS:
  • CSM - Disabled
  • IOMMU - Disabled
  • VT-D - Enabled
Thread moved!
You should not use npci flag when you already have 4G Decoding Enabled.
Secondly, attach the EFI to check!
Hi. I try both with/without "npci", but have randomly result. Black Screen more frequently. EFI attached. Tnx.
Use iMac20,1 SMBIOS and you should be good to go!
adamnor206
