Asus B760M Plus Wifi DDR5 + Intel i7 14700K
timwozni
Gigabyte H510M H V2
Intel i5 11400
MSI RX6800
  1. Mac Pro
I want to assemble a new system to install in Sonoma. I preferred the following. Will I have compatibility problems?
Can it be patched like we patched the CPU for the 11th generation?
https://www.asus.com/motherboards-components/motherboards/tuf-gaming/tuf-gaming-b760m-plus-wifi/
iCUE H115i RGB PRO XT Liquid CPU Cooler
https://www.corsair.com/us/en/p/cpu...15i-rgb-elite-liquid-cpu-cooler-cw-9060059-ww
Intel i7 14700K
MSI RX6800
DDR5 32GB
Kingston, SkHynix
Corsair 4000D Airflow
Intel i7 14700K
MSI RX6800
DDR5 32GB
Kingston, SkHynix
Yes, its all compatible. Just make sure you use a Kit RAM as per the QVL for optimal performance.
iCUE H115i RGB PRO XT Liquid CPU Cooler is working?
All AIO will work as expected. However, if an AIO pump/FAN is controlled via its Software instead of the BIOS, you'll have to either boot into Windows first and then to Mac or use Liquidctl.
Thanks. I'm thinking of buying this. Will there be an incompatibility?
The Motherboard is compatible for sure. Take care of the PCIe and M.2 slots. Being a B760, they share bandwidth.
mohthearrow
