SOLVED Dual boot Windows 11 ve Sonoma not booting
Thank you for answers. My technical knowledge and language are insufficient. I'm reading right now. I will create EFI again as you said. I will share it with you before uploading it.
I made some changes to EFI. MAC HD booted normally again. Then I booted into windows again. It opened normally in Windows. Then when I tried to log into MAC HD again, it got stuck again.
But this time I turned on verbose mode. And always 1
I found that it was stuck at "nvme...".
Your Windows disk is Nvme.
Could I be missing something in EFI related to this?
Thank you for answers. @EliteMacx86
I created new EFI. But before installing this, I came across something very interesting.
After booting and running the Windows operating system, I restart it again. When I entered the BIOS while it was booting up, I noticed that the Lan MAC Address was 0000000000i..
I tried to boot from MAC HD this way without touching the BIOS settings. But it got stuck in the same place again.
I turned off the computer using the back power button and waited for 5 seconds.
AND then I opened the BIOS.
I saw that my LAN mac address was shown correctly.
So, every time Windows opened, it changed my Lan MAC address in my BIOS to 000000000. Until I unplug it and plug it in.
For this reason, I set Onboard Lan Controller=disabled in the BIOS.
Then I booted Windows.
Then I closed windows.
Then I booted the mac hdd.
And finally it opened without any problems.
Then I went back into Windows, shut down, Mac again, Windows again, I was able to switch constantly without any problems.
But the internet does not work because Onboard Lan Conroller=disabled.
I think I made a good point, but I don't know how to solve the problem.
I would be very grateful if you could help?
Thank you for your help. @EliteMacx86
I solved the problem.
My original gigabyte driver was updated with Windows Update. For this reason, I reinstalled Gigabyte Lan Driver. And my physical mac address was completely fixed and never reset.
And thus, I was able to log in to both Mac and Windows easily.
No problems occur.
No problems occur.
Glad you were able to solve the issue.
Marking Solved and closing this thread!
xmax114
