Sonoma lags and freezes on amd laptop
nisel
Acer Nitro 5 AN515-43
AMD Ryzen 5 3550H
AMD Radeon Vega 8
Sonoma is very slow on my AMD laptop, the first thing that appears on the screen is a gray screen for 10 seconds, then for 20 seconds everything works fine, after which everything freezes for about a minute and starts 1 frame in 3 seconds, and even then go through the initial setup impossible because after accepting the terms of use the system freezes. If I remove NootedRed, everything works fine, I was able to get through the initial setup. If you then enable NootedRed, the system will work normally for about 1 minute, after which everything will freeze
My laptop is: Acer Nitro 5 AN515-43 with Ryzen 5 3550H and Vega 8
EFI was created according to a guide from the YouTube channel
Sorry to send this here, it is most likely a NootedRed issue.
ploukop
