Help for Ryzen 7 5800h MacOs Installation
fedorac0re
svi
r5 5800h
vega 8
11.0.x
  1. Other
Hello
i have a MiniPc
Ryzen 7 5800h with apu
this mini pc : Beelink Ser5
can you help me with macos installation?
I have tried to create a few efi's by watching your videos but without success, even though I do the exact same steps, I get a black screen, I can't get to the installation process...
I would be very grateful if someone can help me.
Hello
i have a MiniPc
Hello.
I did everything exactly as in the video, but again the computer stays in black screen, I am attaching my EFI file, can you please help me?
Hello.
Why are you using EnableWriteUnprotector and RebuildAppleMemoryMap together? The guide does not mention to do so. Disable EnableWriteUnprotector and enable RebuildAppleMemoryMap.
You're having KP. Ensure your BIOS settings are correct. Locate the EC device and ensure it exists in the SSDT.
I made the change but I'm getting the same error.
What do you mean by EC device, where should I add what in SSDT, sorry I don't know much, I'm just trying to learn...
What do I need to change in the bios settings? there are not many options in the bios.
I just turned off secure boot.
I am attaching videos of my bios, I would be grateful if you could tell me what I need to change in which section.
this is my efi
add port map and add with SSDT Time .aml file...
but same result... :cry:
ANARKRUTOI
