MSI GS73VR 7RG Laptop build From GE62 7RE?
icet40
GS73VR 7RG
I7-7700HQ
GTX 1070 Max Q
12.x
Hi I had a working Hackintosh build from my last laptop (GE62 7RE) that has recently broken due to plugging in power into the usb c port... the problems our future holds.. haha whoops!. I got a laptop that has very similar specs except the graphics card and perhaps other things. It only boots up halfway on the loading bar and then crashes afterward. I've tried updating opencore and looked at the logs ending with [EB|LOG:EXITBS:START]. I've tried everything in the dortina guide and nothing seems to help. i have a BCM Wi-fi card installed as well. Sorry this is only my second working Hackintosh build
Any help would be greatly appreciated
Thanks!
Cole
Thanks!
Cole
Modern Technology has its own cons ;)
Provide the EFI you're using to boot. Also, are you using the SSD from the previous system or is this a clean install? What macOS version are you trying to boot?
Yes im Using the same SSD as the last Laptop. The Mac OS is Monterey.
The .zip file is corrupt. Please check it again.
Really Sorry about the wait here is the new file.
I don't understand what parts am i missing?
Thanks
Cole
oleksii
