WARNING! The last step only works for Mojave 10.14.(0, 1, 2, 3). If you are upgrading from 10.14.(0, 1, 2, 3) to higher version, first delete all of the files for HD3000(the ones provided in the zip on the first page of this thread)  located `System/Library/Extensions` then upgrade or you will end up with a black screen after boot. Here is a easy to install standalone package with fixes for each version of Mojave. On the `Installation type` selection, make sure you select only one of the provided 3 choices that is meant for your Mojave version.
Before applying this patch make sure you follow the steps from 1 to 4.
