Sorry, i am new at this platform so what is it meaning PR files. I am using intel power gadget Gfx looks like constant 0.65ghz
PR means Problem Reporting files.
I hope I did it properly also my system isn't stable, freezing in a few hours after system boot.I thought reason of video card problems
Several things are not upto the mark.
The ACPI is not patched. Follow the guide here: https://www.elitemacx86.com/threads/guide-how-to-patch-laptop-dsdt-and-ssdts.178/
The config.plist is not as per the guide. Follow the guide here: https://www.elitemacx86.com/threads...ller-on-laptops-using-clover-uefi-legacy.177/
The config.plist is having an invalid Fake ID. It will result in non-working of Graphics.
Still old method is being used to fix the Brightness. Follow the guide here: https://www.elitemacx86.com/threads/guide-how-to-enable-backlight-control-on-laptop.182/
Reactions: Kevin Aguierre
Thank you so much I appreciate that my system is stable finally.. but intel hd 3000 ghz still same as before. I got "Error loading kernel cache (0x9)" when I load Rehabman's config that's why I am using my config similar to Rehabman's so should I do another fix or patch?
Dear,
to first thank you for your help
I want to install on a Packard Bell Laptop Mojave
It have a second gen i3-2250M CPU
6GB RAM
The Laptop boot to the installer and system without problems but every time after I installed the HD Graphics 3000 driver the monitor turns black when I boot the system. If I dont install the driver the monitor show up and everything seems to be fine but the VRAM is only 5MB
I tried many different solutions but nothing helped
The DSDT is patched with a HD Graphics 3000 high resolution and with a GF0 to iGPU rename patch
IOReg Log
DPCI Screenshots
Clover Folder
HD Graphics 3000 driver that I used
Dear,
6GB RAM
IOReg Log
DPCI Screenshots
Clover Folder
No kextcache output attached.
The ACPI is not patched properly. It must be saved as .aml extension to read. Follow the guide here: https://www.elitemacx86.com/threads/guide-how-to-patch-laptop-dsdt-and-ssdts.178/
NullCPUPowerManagement must be removed.
Update WEG+Lilu and the other kexts.
Remove the kexts related to HD 3000. Install the package with the appropriate selection. Rebuild the cache. Restart and reply with new files. If possible, provide the screenshots for the package you install.
WARNING! The last step only works for Mojave 10.14.(0, 1, 2, 3). If you are upgrading from 10.14.(0, 1, 2, 3) to higher version, first delete all of the files for HD3000(the ones provided in the zip on the first page of this thread) located `System/Library/Extensions` then upgrade or you will end up with a black screen after boot. Here is a easy to install standalone package with fixes for each version of Mojave. On the `Installation type` selection, make sure you select only one of the provided 3 choices that is meant for your Mojave version.
Before applying this patch make sure you follow the steps from 1 to 4.
OMG thanks so much for this installer package!! Upgrading from 10.4.4 to 10.4.6 gave me the black screen, but your installer package did the trick quite nicely.
I'm not on a laptop (an older Gigabyte mobo with HD3000 graphics) but this solution still worked, so thanks again!!! :)
Nice!
I was quite busy. That's normal cause Rehabman's config has slide=0 enabled in Boot options. Remove that. Use that file to boot. It will boot. Attach the new PR files.
when I use many tasks, the device lags, it becomes unusable. The device must be turned off by the power button.
jonsv2
