but i am able to boot in mac os and use wifi and everything works except the igpu or dgpu mainly the hardware acceleration even my trackpad and usb mapping everything works i am using macos 12.6.5 so is my apu even supported i doubt it?
Just because you're able to boot into macOS, it does not mean the configuration is as it should be.
Provide the Device ID and Vendor ID to double check.
Well, it's quite simple. You can grab the Device ID and Vendor ID from the Hackintool>PCIe
So sorry for late Reply Here is the Screen Shot if anything you want i can provide :)
Seems like you still need to wait, no ETA as of now for the support for 680M.
Sad Season 2 GIF by Friends
bro
i need efi file like your pc spec, can you send your efi, i have problem in my pc
xmax114
