Trying to convert an ASUS UX482EA to Ventura on even Sonoma
carlitosh
Gigabyte Designare z390
i9-9900 K W/ 64Go of DDR4 3466 corsair
AMD Radeon RX 5700 XT 8 Go
  1. iMac Pro
  2. Mac Pro
  3. MacBook Pro
Complete or almost specs are :
CPUIntel Core i7-1165G7 Processor 2.8 GHz (12M Cache, up to 4.7 GHz, 4 cores)
RAM32GB 4266 MHz LPDDR4X on board
GPUIntel Iris Xe Graphics
Storage1TB PCIe 3.0 x4 NVMe SSD
DisplayMain Display 14inch FHD (1920 x 1080) 16:9 IPS-level Panel, LED Backlit 400nits, sRGB: 100%, Pantone Validated, Anti-glare display Screen-to-body ratio: 93 %, With stylus support 4 mm-thin bezels
Four-sided frameless NanoEdge design with 90% screen-to-body ratio
3.5mm-thin bezel
ScreenPad Plus 12.65” 1920 x 515 IPS-level touch display
stylus support
Ports2 x Thunderbolt 4 USB-C with charging 1 x USB 3.2 Gen 1 Type-A 1 x full size HDMI 1.4 1 x 3.5 mm audio jack 1 x MicroSD Reader
ConnectivityWi-Fi 6 Bluetooth 5.0
CameraHD IR webcam with Windows Hello support
AudioCertified by Harman Kardon Array microphone with Cortana voice-recognition support AI Noise-Canceling
Battery70Wh 4-cell lithium-polymer battery
65W power adapter
Dimensions324 x 222 x 16.9 mm 1.57 kg
I will try to find more on components.
And USB Drive I used as I left it aside months ago.
Full spec from my windows buddy.
I'll find EFI, rebuild it and tell U guys
Well, it's Tiger Lake which is not supported. Of course, you can install macOS but there's no point as it will not have Graphics acceleration.
Yes, maybe, a genius will find a way to make it work (or not) w/graphic acc°
It was never supported, so not unless without a third party kext.
Indeed. Thx
Reactions: carlitosh
wyattst99
