ACPI isn't patched correctly. You must patch them correctly. Some invalid kexts are being used along with improper configuration.
Its probably not the patching process (how) but what patches I have used or not used. Same with the config or kexts. I am a bit lost there. Everything else seems to be working fine. Please give me some more clues - what patches should I use? anything specific in the config? what kexts are invalid?
Fresh Copy ,High Sierra ,I installed Apple ALC ,but I tried all layout-id ALC256 no sound
on the id 28 I have Output-Internal speaker + Headphone Input -Internal microphone but no sound on the speakers.
Also I tried AppleHDA patched-no sound both Id 2 & 3
Hi there
i followed your guide but it didn't work for me
please check my configs and help me
thanks alot
This requires a manual patching from the dump. On some systems, you need to tweak it.
The system is old. macOS Mojave 10.14.6 is the latest for the Mojave.
IOReg should be in valid format, not the text format.
No kextcache output provided.
The system is not a vanilla but Niresh distro. Is a complete mess.
You should start here: https://www.elitemacx86.com/threads...ller-on-laptops-using-clover-uefi-legacy.177/
Reply with new files.
thanks for your help
but I tried to install mac os 10.14.6 a few weeks ago with guides of some sites but it got stuck on last minute and I waited up to 20 minutes for it to finish but it doesn't progress anymore and then I decided to install niresh Mojave that installs easily and works but with some issues in audio and graphics.
now I tried your guide with a usb3 flash memory but it doesn't even boot to installer. Can you please help me to install a proper mac os on my laptop?
Do NOT use Niresh or some other distro. Those are full of crap
Hi i have laptop Acer 4752 with audio alc269 i try this patch but not success any help?
ezreensan
