Intellij IDEA show this message, then I guest that do not enough VRAM.
hello, I tried to install nootedred along with all accurate kexts and after verbose mode it gives a black screen, I see the problem is solved in the comments, but nothing above helped, like disabling SIP, seeing bios settings, checking kexts and etc. need help.
my specs are on my account, heres my efi.
Hey Bro , I am having this AMD GPU Problem , i tried alot of config and bios setting i still cant figure it out , i have both agpu and dgpu . I am using 3400G and rx580 . Motherboard Msi Tomahawk B450 max II . I just want RX580 if cant agpu will do .
3400G EFI - efi file do check this out if i missed anythig , please .
i am using MSI B450 Gaming Plus motherboard.
CPU is R5 5600G
Ethernet RTL Gigabyte 8811
can anyone create a efi file for me. i have been trying for last 15 days to create this efi. but cant make., please help me
CPU is R5 5600G
what is the latest version we can install for now??? is it Catalina or Ventura?
How disable this: "SSDT-PNLF, WEG, WhateverRed, SMCLightSensor, AGPMInjector" ?
J.An
