I am running a laptop with ryzen 5 3500u cpu and 8 gigs of ram. Due to WhateverRed.text Apu graphics are now able to work on hackintosh. I was trying to install big sur on my laptop but i get OCB: Load IMage Failed error. before this i tried installing via opencore release version to install ventura and there, after booting via USB it showed three things:
a gear image with hack.dmg(the name entered for usb)
windows
openEFI shell
After i click on hack.smg it hangs and nothing happens.
CAN SOMEONE PLEASE HELP! other people on the hackintosh subreddit have achieved results with the same specs.
Attach your EFI.
Amd 5500u and Amd 7940hs cpu compatible
Amd 5800h cpu compatible
Hi guys, i have successfully boot Ventura and got full VRAM 512Mb on Radeon Graphics 8. But i need to increase the VRAM to 1Gb.
I have try with Smokeless but on my PC not show menu try to modify VRAM any more.
Do you know how to patch VRAM for get more VRAM?
Please provide the specs of your target system.
  • Love
Reactions: truongvantuan
You try unlocking using the UEFI Shell method. Are you having any sort of issue?
Could you share the tutorial? I have done some searching for HP BIOS Modify but no result.
alvarg82
