Everything is running smoothly (Big Sur), expect problems with all browsers (not Safari) and sometimes Telegram Messenger, which causes the system to restart. Will there be a solution for this? Thanks for the guide!
Well, as mentioned in the guide, the kext is still in the development phase and there is no final release yet, so hopefully, eventually the issues will be fixed.
Reactions: AlexSmqp
How to Enable AMD Integrated Graphics (APU) on macOS [Clover/OpenCore]​
An EliteMacx86 Exclusive Guide - This guide describes how to enable AMD APU Graphics on macOS and is applicable to both, Clover and Opencore. By following this guide, you'll be able to achieve full QE/CI on your AMD CPU with AMD Integrated Graphics.
AMD CPUs have been supported on macOS for a while since High Sierra using the third-party vanilla-style Kernel patches developed by notable developers in the community. However, it has always required the use of dGPU to make it work, regardless of the macOS version. This becomes a problem for users who want to have a limited experience i.e. a basic system with not much Graphics capability due to their use case.
Before this, it was not possible to use any AMD Integrated Graphics (APU) on macOS. This included Laptops and Desktop based Graphics and it was recommended to disable the IGPU either from the BIOS or using one of the approaches under macOS and the AMD GPU support was limited to Desktops only and certain discrete models which were compatible with macOS/OS X on Laptops.
However, with the efforts of developers in the community and with the recent development, there is a new driver NootedRed (formerly known as WhateverRed) and it is now possible to use APU on macOS, and that too with full Graphics Acceleration.
Nonetheless, this has involved a great amount of time in bringing AMD APU support for macOS, approximately more than 2yrs but fast forward to two years of development, and yet continuing there's eventually support for AMD APUs on macOS and hopefully, there is more to see.
Please note that this is an early stage of development for AMD APUs on macOS and as of now, this could be a limited experience. Certain features may not be available and bugs are present and there can be issues across different systems, but an official version has to be released yet.
Following are the requirements for enabling AMD APU on macOS. Please ensure you meet the requirements before proceeding with this guide.
  • macOS Compatible UEFI Motherboard.
  • macOS Compatible AMD CPU. See CPU Compatibility for more information.
GPU
VRAM
  • 512MiB VRAM minimum, 1GiB or more for proper functionality
Boot ModeUEFI. Legacy Boot Mode isn't supported yet. CSM must remain disabled.
  • Pre-installed macOS Big Sur 11.x
SMBIOS
  • MacBookAir, MacBookPro, iMac, iMacPro, Mac mini, MacPro
  • The SMBIOS requirement remains the same as previous.
Monitor
  • Any monitor/TV with DP/HDMI/DVI display connection.
  • DVI users can use DVI to HDMI adapter/cable.
  • DP users can use DP to HDMI adapter/cable.
  • Clover
  • OpenCore
  • Vanilla Graphics Kexts in S/L/E
  • Lilu 1.6.4 or newer
  • NootedRed (formerly WhateverRed)
Compatibility
For more information on APU compatibility, refer to the thread linked below.
Assumptions
The very first step is to set up BIOS to have the AMD APU Enabled on your System. If you have followed the NVIDIA Graphics Guide, you will not require this step. However, If you haven't, follow the steps below to set up your BIOS for AMD APU.
2. Set the following parameters as shown.
SettingsValueNotes
SVM ModeEnabledThis is usually found in Advanced>CPU Configuration.
Above 4G DecodingAuto/DisabledThis is usually found under Advanced>PCI Configuration.
Resizable BAR/Clever Memory Access (C.A.M)DisabledThis is usually found under Advanced>PCI Configuration.
UMA Frame buffer SizeAutoThis is usually found under Advanced>Onboard Devices Configuration.
Integrated Graphics ControllerAutoThis is usually found under Advanced>AMD CBS>NBIO Common Options>GFX Configuration.
UMA Above 4GAutoThis is usually found under Advanced>AMD CBS>NBIO Common Options>GFX Configuration.
IOMMUEnabledThis is usually found under Advanced>AMD CBS>NBIO Common Options
Primary Video Adaptor (IGD)Int Graphics (IGD)This is usually found under Advanced>AMD PBS.
CSM (Compatibility Support Module)DisabledThis is usually found under Boot
3. Save & Exit Setup
STEP 2: Add Required Kexts
The next step is to add the required kexts to enable APU Graphics. NootedRed doesn't work standalone. Lilu and NootedRed is needed together to work in conjunction. To install the kexts, follow the steps below.
1. Download Lilu and NootedRed.
For Clover:
If you're using Clover, copy all the kexts to EFI/Clover/Kext/Others directory.
For OpenCore:
If you're using OpenCore, copy all the required kexts to EFI/OC/Kexts directory. You'll also need to add the kext entries in the Kernel section of your config.plist
4. Save config.plist
STEP 4: Restart your System
Verifying Graphics Acceleration
The next step is to verify whether the graphics acceleration is working or not. Follow the steps below to verify the Graphics acceleration.
About This Mac
  • Verify the GPU Model Name and VRAM in About This Mac
  • Verify the monitor size and resolution in About This Mac>Displays
  • Verify the GPU information in About This Mac>System Report>Graphics/Displays
System
  • Verify the transparency in Dock
Hello my Freand. Thanks for the hellp. I need hellp on my EFI, i'm using a Ideapad S145 AMD Ryzen 7 3700U Radeon Vega 10 , can you hellp me seeing what i'm doing bad? Please hellp
Could you describe the issue?
Hello dear friends! I glad to see this NEWS ! My RX6400 doesn't support as native. But i have Ryzen 3 3200GE and want to try to do that. Who can help me with that? I installed one time Big sure and have some experiense. But not sure i will do it for SONOMA.
It's ready for Sonoma!
Hi. Please help me, I have followed the MacOs opencore installer on the official website. On the initial boot process I got the message "OCB LoadImage Failed". Tried MacOs Mojave, my device is Msi A68HM-E33 V1, CPU Amd A4 6300, VGA integrated onboard APU. Thank You
Your APU isn't supported and there's no point in running macOS without the graphics acceleration.
I am running a laptop with ryzen 5 3500u cpu and 8 gigs of ram. Due to WhateverRed.text Apu graphics are now able to work on hackintosh. I was trying to install big sur on my laptop but i get OCB: Load IMage Failed error. before this i tried installing via opencore release version to install ventura and there, after booting via USB it showed three things:
a gear image with hack.dmg(the name entered for usb)
windows
openEFI shell
After i click on hack.smg it hangs and nothing happens.
CAN SOMEONE PLEASE HELP! other people on the hackintosh subreddit have achieved results with the same specs.
xxxxxxxxxx
