- Jan 16, 2023
- Asus H61 MK
- Intel(R) Xeon(R) CPU E3-1275 V2 @ 3.50GHz
- NVIDIA GeForce GTX 670
Yes, it will work. But if you're going to use PCIe then instead of using Intel, why not use Broadcom Card to have full features?Hi everyone, I want to buy a wifi card that I will use with my Hackintosh Monterey PC later on
Most cheap wifi cards supported by hackintosh are M2
What if I use a PCIE x1 to M2 adapter? will it work?
Oh, sorry to hear that. What's the price difference between both the Cards?Thanks for ur reply
Price of Brcm cards that supported by monterey very expensive on my country
I have read few forum, no workaround to bring back old and cheap brcm card that support by older MacOS to monterey
Well, it's your take but if you use a supported Broadcom Card, WiFi and Bluetooth should work with full features.Taking reference from dortania, here are the prices of supported cards in monterey:
BCM943602 = Rp 2.085.000,00
BCM94360 = 1.207.000,00
BCM94352 = 598.000,00
BCM94350 = 567.000,00
BCM94322 is very cheap 140.000,00 , but only support Mojave (10.14) and older
cards above are price without adaptor
but
INTEL AC7265 with Adaptor only 299.000,00
