Guide to install Monterey 12.2.1 in a Acer Aspire ES1-572 - All Working Wi-Fi & Bluetooth - Opencore 0.7.8 - BCM94360NG
fernandocneves
T-rex
i5 6200u
Intel HD 520
1411163178_CapturadeTela2022-02-12s08_22_37.png.4a8966723554a9a35c04d857c98601c0.png Install Guide to install macOS Monterey 12.2.1 with everything working Out-Off-The-Box
  1. Download macOS Monterey 12.2.1 from Apple Store
  2. format an USB 16Gb or Bigger
  3. Type in Terminal:
    • diskutil eraseDisk JHFS+ "macOS Monterey Installer" /dev/pathtoUSB
    • cd /Applications/Install macOS Monterey/Content/Resources
    • ./createinstallmedia --volumes /Volumes/"macOS Monterey Installer"
  4. After completion, use this EFI folder:
    • mkdir /Volumes/EFI
    • mount -t msdos /dev/disk?s1 /Volumes/EFI
  5. Open Finder (/Volumes/EFI)
  6. copy EFI directory provided in this folder
  7. Restart and boot macOS Monterey Installer
https://drive.google.com/file/d/1kLkOJ0UV-03uyA1hiLKTWtG1qpRsvjg2/view?usp=sharing ==> EFI folder with Opencore 0.7.8 - All Working
This is a JMicron SD Card Reader Driver for Monterey 12.2.1 https://github.com/chris1111/JMicron-Card-Reader/raw/main/JMicron-Card-Reader.pkg.zip
AppleALC => boot-args => alcid=15 - ALC235 (Works Laptop Speaker + Microphone + HDMI)
Wi-Fi & Bluetooth => BCM94360NG m.2 (Replaced from Original) works Out-Off-The-Box.
LCD 1366x768 replaced by 1920x1080p LCD.
Battery Status Working.
Siri working.
Screen Mirroring working.
Hibernation working.
USB 3.0 working.
AirPlay 2 Working.
AirDrop Working.
What is working?
Everything!!!
What's not working?
Nothing!!!
Successfully Hackintosh with dual-boot with Latest Windows 11 Home single language PT-BR 21H2. Used Rufus to build an USB with Windows 11 installation without TPM 2.0 Check.
OpenCore 0.7.8 + DSDT.
Geekbench 4 score (7148) https://browser.geekbench.com/v4/cpu/16447850
Acer Aspire ES1-572 - i5 6200U - 16GB Ram 1866Mhz - Intel HD Graphics 520 - Display: 15.6" 1920x1080p - 2x SSD Kingston 240GB each
MacOS Monterey 12.2.1 - Everything works - BCM94360NG m.2 Wi-Fi + Bluetooth Plug&Play + SideCar. Dual Boot with
Windows 11 Home Single Language.
iPhone 7 128Gb - IOS 15.3.1
iPad mini 2 - iPadOS 12.5.5
Apple Watch Series SE - WatchOS 8.4.1
MacBook Pro 13 Retina (Early 2015) - macOS Monterey 12.2.1 - 512GB Nvme SSD (3gb/s Read & 1.4gb/s Write) - 8GB 1866Mhz Ram Dual Boot (BootCamp) with Windows 11 Home Single Language.
View attachment 4090Install Guide to install macOS Monterey 12.2.1 with everything working Out-Off-The-Box
Siri working.
USB 3.0 working.
AirPlay 2 Working.
AirDrop Working.
What is working?
Everything!!!
What's not working?
Nothing!!!
Acer Aspire ES1-572 - i5 6200U - 16GB Ram 1866Mhz - Intel HD Graphics 520 - 2x SSD Kingston 240GB each
iPhone 7 128Gb - IOS 15.2
Apple Watch Series SE - WatchOS 8.3
This is sick! Kudos:)
what is the point of inserting a link to EFI files and then blocking access to it and not responding to requests for access
Also, you should fill in your system specs in your profile.
Write your reply...
chun1980
