SOLVED OPENCORE REBOOTING AFTER SELECTING INSTALLER
Nope its still not working :(
Note; When I booted into Installer the WIFI showed up.
Remove all other WiFi kexts. Build kextcache.
There are no other WiFI kexts other than Airportitlwm.
Your kextcache output shows you have Realtek WiFi kexts. Probably, USB one.
Can you please review my EFI and tell which kext to remove because i cant figure out what kext to remove. Please and ThankYou :)
EFI
EFI
Provide Kextcache output.
The output looks clean.
However, it is not working because you've injected kext directly into OC, which cannot always be used as it is not always possible to inject using userspace.
Remove IONetworkingFamily.kext completely from Kernel>Add section in your config.plist and also from the EFI/OC/Kexts directory.
Once you're done with the changes, save your config.plist and make sure to empty the bin. Restart the system and reset NVRAM twice. Attach the new PR files.
NCC74656
