wifi and bt adapter with handoff and continuity camera
hexsander
B450 AORUS M (rev. 1.x)
ryzen 5 2600
rx 580 8gb
  1. Mac Pro
I am looking to buy an wifi and bt pcie card but to much confuse as in India they are not available at all and those are available are to costly I look Fenvi also still costly
can anyone please help me to guide proper for buying it will be great gesture I have Mac Pro 2019 hackintosh model with Sonoma installed running well and stable no issue just need full apple feature of airdrop handoff , continuity camera and side car feature 🙂 please help me
You literally have no alternative other than buying that particular hardware.
can you list all working model currently on latest Sonoma out of the box with all feature handoff / airplay/ continuity / airdrop .. from that list I ll check and look which is available for me to buy right know all pcie models 🙂
None. Currently, no WiFi/BT cards work OOTB under macOS Sonoma. Since Sonoma, you'll have to patch it. The recommendation is Broadcom which requires patching root volume. An extensive guide already exists.
I ll do patch but at least give me some pcie model adapters like Fenvi FV-HB1200M model can you please tell me more 5 more models
@EliteMacx86 so which one I should buy from these adapter and works well >
Another is Fenvi T919. The other are Apple AirPort card with a compatible Adapter.
eroldemirer
