Tahoe does not want to install with my efi
Joeytic
Gigabyte Z490 Aorus ultra
i7 10700
Rx 590 8gb
15.x
  2. Mac Pro
  3. Mac mini
  4. MacBook Air
  5. MacBook Pro
Hello, I’m posting about my failed attempts to upgrade to macOS Tahoe.
I managed to update once before, but I had to roll back, and now I can’t upgrade to Tahoe again no matter what I do.
I’ve customized my EFI multiple times, and it works perfectly with Sonoma, Sequoia, and even Ventura. But the moment I try to update to Tahoe, everything breaks. I tried using the OTA updater, which worked once, but now every time I download Sonoma and attempt to update, it crashes at the macOS installer stage and completely breaks my system. I’ve wasted a huge amount of internet quota trying to fix this.
I also tried using prebuilt EFIs from multiple YouTube guides, thinking the issue might be my EFI. On top of that, I tested the raw offline installer from Olarila and the Tahoe recovery image. None of them even open the installer — the system just keeps restarting before it can enter the installer.
At this point, I’m completely stuck.
saiyajin
