OpenCore Wireless Issue
SteveWaters
  1. OpenCore (Legacy)
Good Morning Everyone:)
I have a Macbook Pro 8,1 running on OpenCore 1.3.0. After updating Sonoma, I lost wireless. I have run the post install menu a few times with no luck. I have Vmware Fusion running Win 11, with no network issues.
Does anyone know what I did wrong?
Can I fix this, or do I need to wipe?
Thank you for any help.
So, a real MacBook running macOS Sonoa and has no WiFi. The same MacBook also runs VMware Fusion which has Windows 11 right?
Run Hackintool and provide PCIe info and the include System Report too.
Reactions: SteveWaters
I hope I did this correctly. Thank you for the help:)
Yes, but not the other part ;)
The System Information can be saved using About This Mac>System Report>File>Save.
Also, include a copy of IOReg.
IOReg I think is a file, I will go search for it.
I did, I just renamed the extension to txt.
Sad Cry GIF by SpongeBob SquarePants
So as per the System information, the WiFi seems to be working. Can you explain where's the issue you're getting?
Snowson
