help im stuck at this menu
barre
ASUS ViVOBOOK 14 PRO OLED
Ryzen 7 5800H
AMD Radeon (TM) Graphics
I See your error,
its is because you didn't change the efi folder to your supported processer
You need to install the efi that will match for your processer's codename
Also By the way can you specify some what clearly?
(like if your booting on pendrive or hardrive or this is happening after post installation)
if it dint work try chaning the efi
(from Opencore to Clover)
(or Clover to opencore)
Refer Here
If you have any further problems feel fee to ask me :)
xxxxxxxxxx
