Hard drive bays on my Hackintosh PC (2.5-inch and 5.2-inch) don't support hotplug
fritz122
MSI Z370 A PRO
i5-9100
AMD Radeon RX6600XT
15.x
Hard drive bays on my Hackintosh PC (2.5-inch and 5.2-inch) don't support hotplug.
I want a SATA3 SSD to be recognized by Sequoia 15.7.4 when I insert it into a drive bay while the system is running. If I insert the SSD beforehand and boot into Sequoia 15.7.4, everything works normally.
Do I need to enable the hotplug option in the BIOS of my MSI Z370 A PRO motherboard? I don't think so, because hotplug works under Windows 11 even while the system is running, without hotplug being enabled in the BIOS.
I want it to work the same way in macOS Sequoia 15.7.4.
I previously had this working under Big Sur by finding 40600200 and changing it to 00000000 using com.apple.driver.AppleAHCIPort,
but this no longer works under macOS Sequoia 15.7.4.
I have two kexts for SATA in OC 1.0.6:
CtlnaAHCIPort.kext and NVMeFix.kext
I would greatly appreciate any help with this.
Solved it myself... I had disabled hotplug for all SATA ports in the BIOS, because that's usually how it's done with Hackintosh systems.
After enabling it, everything works perfectly.
And I also added something to PCI Root for my SATA controller in Device Properties.
kcbednar
