Guide incomplete
whatisgoingon
MSI Z690Pro
i5 12400F
GTX 770
12.x
I was trying to follow the OpenCore guide
but all the links are missing:
Also for the step after that the validation is missing:
Or am I missing something?
The whole guide will be refined very soon. We're working on it to remove the complexity involved. Meanwhile, you can follow the video guide
Thank you very much for the link, I tried to follow it and currently get stuck at this error:
You did not follow the guide carefully. The config.plist is not cleaned up and the files are not as per the guide. Follow the guide again properly.
My files are for Alder Lake, they should be correct. Or not? I just double checked them
It should be but it is not. Watch the guide carefully and re-attach the EFI to check.
jkzql77089
