BEP: Invalid revision 2 (!= 1) in loaded driver
pinguino
Asus
i7 9700k
10.13.x
  2. OpenCore (UEFI)
I need help booting i cant get past this.
No PR files attached.
What are PR files im sorry im new?
Please read the FAQ. It's described.
Hardware information not provided. BIOS Settings not attached.
Here are a few issues. Make the following changes to your config.plist:
- Remove ResetLogoStatus Quirk in ACPI>Quirks section.
- Remove the following kext entries from Kernel>Add section. The related kexts must be removed from the OC/Kexts directory too.
  • AirportBrcmFixup.kext
  • AirportItlwm.kext
  • AppleALCU.kext
  • BlueToolFixup.kext
  • FeatureUnlock.kext
  • HibernationFixup.kext
  • IntelBluetoothFirmware.kext
  • IntelBluetoothInjector.kext
  • MacHyperVSupport.kext
  • RTCMemoryFixup.kext
- Enable the following Quirks in Kernel>Quirks section
  • AppleCpuPmCfgLock
  • AppleXcpmCfgLock
  • DisableIoMapper
  • PanicNoKextDump
  • PowerTimeoutKernelPanic
  • XchiPortLimit
Enable the following in Misc>Debug section
  • Disable WatchDog
  • AppleDebug
  • ApplePanic
- Set Scan Policy to 0 in Misc>Security section.
- Enable AllowSetDefault in Misc>Security section.
- Disable SIP using 67000000 as csr-active-config value.
- Remove the following drivers from UEFI>Drivers section. The related drivers must be removed from the OC/Drivers directory too.
  • BiosVideo.efi
  • CrScreenshotDxe.efi
  • Ext4Dxe.efi
  • HiiDatabase.efi
  • NvmExpressDxe.efi
  • OpenLinuxBoot.efi
  • OpenNtfsDxe.efi
  • OpenPartitionDxe.efi
  • OpenVariableRuntimeDxe.efi
  • Ps2KeyboardDxe.efi
  • Ps2MouseDxe.efi
  • ToggleSipEntry.efi
  • UsbMouseDxe.efi
  • XhciDxe.efi
- Enable ReleaseUsbOwnership in UEFI>Quirks section.
Hi i just tried and i have the same error message would it matter that i have a nvidia rtx 2070super in my build but I'm using my integrated GPU i followed everything you told me i just don't know what order the kexts and drivers should be in
okay so i need help it just gets stuck on this now I fixed the last part I just needed to update my opencore 1668488447521.png
NVIDIA RTX isn't supported. See NVIDIA GPU compatibility for more information.
OpenUsbKbDxe.efi is not removed.
shakk
