Encoding starts successfully, but it is very very very slow. I can estimate that encoding via iGPU(UHD630) was 50 times faster than using dGPU(RX6600XT). My expectation when I bought the card was that dGPU will be faster then iGPU ...
What macOS version are you using?
No, only one OS - MacOS, openCore 0.8.3
Would it be possible for you to install Windows?
Provide Geekbench Metal and OpenCL Scores.
No, I will not install windows on this machine, sorry. However Geekbench results from MacOS installation are bellow and seem to be fine comparing to similar builds ...
There is no way to disable iGPU, there is a PrimaryGPU option only that is set to PCIE. What are PR files ?
alexito
