try this, use layout-id=3.
For ALC299 right?
I guess it's a new a rare codec. Is morning will check it in a while.
Yes to ALC299, in fact I need your IOREG if possible.
but first try the kext I sent you.
Audio icon shows. No Internal Speakers, Microphone works little, Headphones doesn't switch. When using Headphones, noise is there only.
The IOReg is attached.
try this, Layout-id=3
Good news, the Audio works via Internal Speakers. No Headphones, No Microphone
EDIT: When using my Jack Fix script, the noise is not there in Headphones. Complete silent.
The same process works for microphones.
have you tried?
raymondleung416
