Thunderbolt support for Blackmagic Ultrastudio 4K Mini
willgiroux
B550-F WiFi
AMD 3900X
Radeon 5700XT
10.13.x
Hey guys!
I just finished installing all my stuff on my Hackintosh and am trying to get my Blackmagic Ultrastudio 4K Mini to be detected in macOS and can't seem to get it right. The driver from Blackmagic is up to date to 12.2.2 and the card works on my Macbook Pro and on that machine in Windows. It's connected through TB3.
PR:
  1. Titan Ridge (ThunderboltEX 3-TR)
  2. ASUS
  3. AIC
  4. PCI 4x (& it was working in W10 before flashing the firmware)
  5. Flashed firmware NVM56 (Attached) (Have a backup from OEM just in case)
  6. TB Header connected
  7. TB BIOS Settings Available
  8. ASUS B550-F
  9. AMD 3900X
  10. 11.2.3
  11. IOReg isn't opening since I flashed the firmware of the TB card. It just hangs there. Same for Hackintool.
Thank you!
There could be several reasons.
Windows and Mac are two different things. The reason why you have it working on your MBP is that it doesn't require any additional configuration.
Thunderbolt Settings are missing.
That shouldn't be the reason at all. The reason to hang is probably some misconfiguration, either from the BIOS side or the EFI itself.
Well, the configuration is not as per the guide and seems like has been configured by Andresha who builds hacks for people ;)
ebillah
