Help me Installing BigSur in Tiger Lake
A fellow by the name of ANIL-007 over on Reddit claims to have used the build configuration from https://github.com/deniro98/hackintosh-asus-zenbook-duo-ux482ea successfully after having only renoved the "-s" from the boot arguments (https://github.com/deniro98/hackint...37e01a42cb76e6939663456a/OC/config.plist#L993)
I'd like to see if I can reproduce the result, but haven't had time to try yet.
Just installing is not going to help. At least the Graphics should work which is not supported at the moment.
Hello, is there any news? I also have a
11th Gen Intel Core i5-1135g7 and Graphics Iris Xe but I can't install Big sur
Please help me with hp 14s dr2007tu hackintosh installation!
As per your profile, you have Tiger Lake CPU, which is not supported yet.
It can be installed. However, it will lack the Graphics. I haven't got any Tiger Lake hardware at the moment so cannot test it.
You should follow the installation guide i linked above.
Hi, I know I'm late, how do I spoof it?
You cannot spoof something to anything. Spoofing has limitations. As stated above, the IGPU will never work, unless there is a complete development.
kaikkmi
