opencore macOS catalina installation stuck at Your Internet Connection ..please help
openMac
Gigabyte H410M H
Intel i3 10100
Intel UHD 630
10.14.x
i3 10100 Gigabyte H410H M
Realtek® GbE LAN chip (1000 Mbit/100 Mbit)
getting suck at Your Internet Connection .. given option Manually NOT using DHCP
when i attempt to change "Manually" to "using DHCP" then opencore 0.6.5 macOS catalina hangs
here are some of the images of the error and plist ..please help
Go back and select "My computer does not connect to the Internet" and click on Continue. Once you reach the Desktop, use Hackintool to find the Device ID of your Ethernet Chip and install the correct kext.
thanks for replying .. I have tried it and I can not boot once I remove the usb after installation .
no error thrown ..BIOS is not detecting HDD and if I enabled CSM UEFI then it detects but once I restart BIOS again it is gone .
SATA Controller is showing HDD but Boot Option and Boot Override is not showing HDD even after installation .
I have uploaded config plist in text format ..Opencore Sanity checks cleared the config plist..please help .
No PR files attached.
Roberto Sales
