On Windows, I already installed the driver available on the Asus website and you can see my Apple Thunderbolt monitor working perfectly (sound, USB and camera).
Note that there's no any relation to Mac. As per the forum rules, do NOT tag the members unless it's necessary.
The issue "Thunderbolt: No hardware found" is absolutely normal.
Incomplete PR files attached. Kextcache output is missing.
You did NOT followed the guide. The guide clearly mention to use iMacPro1,1 as a SMBIOS and you're using iMac18,3.
You should attach one without TB work and with TB work to check the differences and status.
I'm sorry to tag it unnecessarily.
I'm new to this world of Hackintosh, I hope you understand, I have some difficulties. And I don't know which PR files are missing or where Kextcache is.
How do I change SMBios? Will I have to format and install everything again?
I appreciate your patience and quick response.
To generate kextcache, use "sudo kextcache -i/" without quotes in Terminal. It's already covered in FAQ section. PR files are Problem Reporting Files.
To change SMBIOS, you can use OpenCore Configurator. Guides are being updated for OpenCore.
I already changed SMBIOS in OC Configurator.
The missing files are the attachments?
  • system.log.zip
    system.log.zip
You don't have even used the correct command in Terminal. Recheck your work and attach new PR files.
I copied all the files revealed in the Console. I hope to be correct now.
If you have a question, do you have a guide for the OpenCore Guide?
KernelCache ID: 94F1A5AB32C5FC9D9311857FF4424538
  • PRFiles.zip
    PRFiles.zip
I'm getting disappointed that I can't send you everything ...
Still incomplete PR files.
You can also check for other users files how they've submitted correct PR files.
Here is a checklist
  • Kextcache output
  • BIOS Settings
  • OC folder excluding resources folder with TB work
  • Copy of IOReg
  • OC folder without the TB work
The way is going to be to wait for the Guide to OC, because I'm not really able to get the PR files. I do not have advanced knowledge in IT and, therefore, I must be confusing some process.
Thank you for your patience and help!
mac300
