Fans at max rpm
CAPED_CRUSADER01
ASUS TUF FX505GE
I5-8300h
Uhd 630 and 1050ti
10.13.x
Hey I installed hackintosh recently with of 0.5.8. I have two fans in my laptop and they're at max rpm regardless the low temps. I've done ssdts patches(pnlf, ec, plug, hpet and power mgmt). I found this in ioreg (info about fan). Is there any way I can create a ssdt to make fans run according to temps?
Laptop model: ASUS TUF fx505ge i5 8300h
No PR files attached.
I've attached efi folder
Incomplete PR files attached. Read here:
I've added almost all the files I have except screenshot of verbose(because I don't have booting problems and I couldn't take it) and bios scrreenshots (for which I have mentioned everything about it in a text file). Hope these informations is useful to solve the problem.
Link: https://drive.google.com/file/d/1JTQoDIGhdDBqti7R08dMv3uprRSRJCX_/view?usp=sharing
Currently, the guide is for Clover only. No support will be provided unless i write a guide for OC.
Oh okay
So can you help me with my problem?
Write your reply...
moraWooChang
