So no good all week on the High Sierra install :( I followd the same steps but the machine turns off and reboots after the clover screen appears and I select install MacOS (it gets to Apple logo then shuts down, a few seconds later it reboots). I'm pretty convinced it;s my config.plist but can not be sure. I found an install guide for a z800 series with High Sierra and that caused kernel panics. Any ideas on what to look for wold be greatly appreciated, the guide for Mojave worked like a charm but my video card has some issues or I would call it a day with Mojave.
Provide your PR files to check.
Thanks for the advice, I found a terminal command to generate a problem report. My question is, do I mount the USB installers EFI partition in terminal and run report on that? I am convinced I am doing something wrong as far as a memory fix. What is your preferred method for generating a problem report? A little perplexed why I had no issues to get at least install (minus graphics card) on mojave and high sierra is a headache? Any help or guidance is appreciated. thanks again and be safe!
You can provide the files manually and compress them in one single .zip file. Currently our servers are upgraded, modification is required and will be done soon. Till then, you use Google Drive link to link your PR files.
Stay safe, stay healthy!
Well great news, I got it to install!!! My BIOS reset it's settings and that was the issue. I dont know why but after the previous shutdowns I wasnt going back to confirm the BIOS settings were still the same. I got ethernet working now and played a youtube video. So this is what I am working on now and have left to figure out:
- Audio : DPCI Manager says nVidia (unknown)
-USB fix (1 out of 3 on front work BUT ALL 4 work on back - il take it though :)
-nVidia 970 updated webdrivers. Is there a newer web driver for my card? (looks great but on log in screen ONLY I get some lines across the screen)
-CPU power management
Back on track and almost there!!
Follow the guide on the first page and you'll have it fixed.
Update 3/30/2020
I got High Sierra Installed
-nVidia Webdriver working
-ethernet working
-Audio is via nVidia HDMI - works very good through monitor BUT is there a way/option to also use the onboard codec and choose in preferences?
Still need Bluetooth
CPU Management
USB ports Still missing 2 on front and the 3.0 ones on the back (al together I have 5 working out of 11 (is there a total fix to use all?)
Cool.
CPU Management
Attach your PR Files to check further.
Here are my PR files:
Please let me know if I uploaded the correct ones.
NVRAM PLIST:
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
<key>EFILoginHiDPI</key>
<data>
AAAAAA==
</data>
<key>LocationServicesEnabled</key>
<data>
AQ==
</data>
<key>csr-active-config</key>
<data>
ZwAAAA==
</data>
<key>efi-backup-boot-device</key>
<data>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</data>
<key>efi-backup-boot-device-data</key>
<data>
</data>
<key>efi-backup-boot-device-data-data</key>
<data>
AgEMANBBAwoAAAAAAQEGAAAdAwUGAAAAAwUGAAEABAEqAAIAAAAoQAYAAAAAAGDyyB0A
AAAAt85qQBs8dkqhPyLWko2IGAICBAMkAPf8dL58C/NJkUcB9AQuaEI1GQwvEprET4dp
gEbsDaHkBASKAFwANgBEADcAOQA3ADkANwA0AC0AOABGAEQAMwAtADQANgAzAEEALQA4
AEQAOQBBAC0ANQBDADUAMQA1ADYARQAwAEEAMgBCADcAXABjAG8AbQAuAGEAcABwAGwA
ZQAuAGkAbgBzAHQAYQBsAGwAZQByAFwAYgBvAG8AdAAuAGUAZgBpAAAAf/8EAA==
</data>
<key>efi-boot-device</key>
<data>
RDMtNDYzQS04RDlBLTVDNTE1NkUwQTJCN1xTeXN0ZW1cTGlicmFyeVxDb3JlU2Vydmlj
ZXNcYm9vdC5lZmk8L3N0cmluZz48L2RpY3Q+PC9hcnJheT4A
</data>
<key>efi-boot-device-data</key>
<data>
gEbsDaHkBASaAFwANgBEADcAOQA3ADkANwA0AC0AOABGAEQAMwAtADQANgAzAEEALQA4
AEQAOQBBAC0ANQBDADUAMQA1ADYARQAwAEEAMgBCADcAXABTAHkAcwB0AGUAbQBcAEwA
aQBiAHIAYQByAHkAXABDAG8AcgBlAFMAZQByAHYAaQBjAGUAcwBcAGIAbwBvAHQALgBl
AGYAaQAAAH//BAA=
</data>
<key>fakesmc-key-#KEY-ui32</key>
<data>
AAAAEA==
</data>
<key>fakesmc-key-$Adr-ui32</key>
<data>
AAADAA==
</data>
<key>fakesmc-key-$Num-ui8</key>
<data>
AQ==
</data>
<key>fakesmc-key-BATP-flag</key>
<data>
AA==
</data>
<key>fakesmc-key-BEMB-flag</key>
<data>
AA==
</data>
<key>fakesmc-key-BNum-ui8</key>
<data>
AA==
</data>
<key>fakesmc-key-EPCI-ui32</key>
<data>
AsAHAA==
</data>
<key>fakesmc-key-MSAc-ui16</key>
<data>
AAA=
</data>
<key>fakesmc-key-MSFW-ui8</key>
<data>
AQA=
</data>
<key>fakesmc-key-MSPS-ui16</key>
<data>
AAM=
</data>
<key>fakesmc-key-MSTc-ui8</key>
<data>
AA==
</data>
<key>fakesmc-key-MSWr-ui8</key>
<data>
AA==
</data>
<key>fakesmc-key-RBr -ch8*</key>
<data>
dDkAAAAAAAA=
</data>
<key>fakesmc-key-REV -ch8*</key>
<data>
ATkPAAAF
</data>
<key>fakesmc-key-RMde-char</key>
<data>
QQ==
</data>
<key>fakesmc-key-RPlt-ch8*</key>
<data>
dDkAAAAAAAA=
</data>
<key>flagstate</key>
<data>
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA=
</data>
<key>fmm-computer-name</key>
<data>
VXNlcuKAmXMgTWFjIFBybw==
</data>
<key>nvda_drv</key>
<data>
MQA=
</data>
<key>prev-lang:kbd</key>
<data>
ZW46MA==
</data>
<key>security-mode</key>
<string>none</string>
<key>specialbootdevice</key>
<data>
AgEMANBBAwoAAAAAAQEGAAIfAxIKAAAA//8AAAQBKgACAAAAKEAGAAAAAABg8sgdAAAA
ALfOakAbPHZKoT8i1pKNiBgCAgQDJAD3/HS+fAvzSZFHAfQELmhCdHl5bdOPOkaNmlxR
VuCit3//BAA=
</data>
</dict>
</plist>
There is ALSO
System Log File
"Users" Mac_Mac_Pro io reg file
I am so close to getting this completed any help is greatly appreciated, everyone has given me great direction thus far.
And please advise me on any other recommendations / advice from what you se that I did not do correctly.
NVRAM PLIST:
<dict>
<data>
AAAAAA==
</data>
<data>
AQ==
</data>
<data>
ZwAAAA==
</data>
<data>
</data>
<data>
</data>
<data>
</data>
<data>
</data>
<data>
AGYAaQAAAH//BAA=
</data>
<data>
AAAAEA==
</data>
<data>
AAADAA==
</data>
<data>
AQ==
</data>
<data>
AA==
</data>
<data>
AA==
</data>
<data>
AA==
</data>
<data>
AsAHAA==
</data>
<data>
AAA=
</data>
<data>
AQA=
</data>
<data>
AAM=
</data>
<data>
AA==
</data>
<data>
AA==
</data>
<data>
dDkAAAAAAAA=
</data>
<data>
ATkPAAAF
</data>
<data>
QQ==
</data>
<data>
dDkAAAAAAAA=
</data>
<data>
</data>
<data>
</data>
<key>nvda_drv</key>
<data>
MQA=
</data>
<data>
ZW46MA==
</data>
<data>
VuCit3//BAA=
</data>
</dict>
</plist>
There is ALSO
System Log File
Incomplete PR files attached. EFI and IOReg is required. Do NOT copy/paste any logs unless the mods ask for it.
oneinchashh
